cometic head gaskets 3.860 .051 J&E stroker piston, fuel cell w/ double pumpers more
ericttype
  1. new cometic head gaskets .051 thick 3.860 bore stage 1 or 2 $150 u cover all fees
  2. new j&e stroker pistons 3.830 bore can run stock rod or 5.970 with 3.625 crank $450 u cover fees over 700
  3. stock frame mount for gbody turbo buick the ones tha bolt to frame $45.00 u cover fees
  4. 16 gallon fuel cell i installed 2 double pumpers 340 pumps all with 10g wire never had gas in it with gm sender $450
  5. new 60mm wastegate not sure what brand i took top off did not put it back together has extra springs no instructions $150 u cover all fees
Couple questions on the fuel cell: What's it coated with, is it just painted black? Doesn't appear to have any baffling around the pumps correct? Are those mounting straps on the left? Is it flat on the bottom or sumped? The pic is titled "Ford Pickup" does that mean the level sensor is not a 90 ohm? Is the pump hangar modified, looks like there's just the outlet and you're using the other fittings for return and vent. Thanks, Scott
its aluminum it just painted with black paint and does have scratches no baffling flat bottom and has mounting strapes pump have maybe 500 miles in my stock tank but like i said the cell has never had gas in it
