going LS alot of performance parts turbo injectors stroker
  1. stainless coolant lines hoses & heater valve $110 shipped
  2. SOLD 72mm throttle body $185 shipped SOLD
  3. stock fuel rail dual feed #8 accfab regulator w/#4 fitting & 1/8" fitting for gauge $160 shipped
  4. 80 lbs injectors with TURBO TWEAK chip just had injectorss cleaned $315 shipped
  5. 80 lbs injectors new $280 shipped
  6. comp 885 race roller hyd lifters new $350 shipped
  7. gn1 fuel pressure regulator $100 shipped
  8. champion race intake with billet fuel regulator $700 shipped
  9. precision 70bb hpq water cooled turbo H cover $1250 shipped
  10. SOLD racetronics injector harness new $60 shipped SOLD
  11. gn1 valve covers with k&n breathers $145 shipped
  12. SOLD stroker crank 3.625 standard in good shape just need polish $600 shippedSOLD
  13. gn1 race ported heads new valves,guides springs set up for hydr roller still at machine shop $1500 shipped new valve springs dual 13 bolt stage 1 or 2
  14. scat stroker rods 5.970 arp 2000 rod bolts been clearened 4 stroker used $400 shipped
  15. NEW dsl custom ground comp cams 224/224 duration @ 50 536/536 lift w/ stock ratio rockers $280 shipped
  16. H&r motor mounts $230 shipped
  17. SOLD 17 powerlogger with ecm wcables $250 shipped SOLD
  18. SOLD scanmaster 2.1 good working order $220 SOLD
  19. j&e stroker piston new in box with rings 3.830 bore 1.718 COMP DIST 5.970 rod 3.625 crank $650 shipped
  20. SOLD bhj sfi internal balanced ta balancer ta v2027 with sensor $390 shipped paid $500 shippedSOLD
  21. scorpion roller rocker for gn1 heads 1.55 ratio new $200 been clearanced for push rods
  22. atr 3" down pipe with external wastegate $375 shipped has 02 bung
  23. SOLD MASS AIR TRANSLATOR SOLD
  24. rjc power plate champion race intake this is for aftermarket intake $80.00 shipped
  25. deep oil pan i made 6 7/8 deep has magnet glued in the bottom hold about 2 to 3 quarts more $130 shipped
  26. SOLD new cam sensor 86-87 had a composite gear on it but i put stock one back on also has rjc ring saver $175.00 shipped SOLD
  27. cometic head gaskets 3.860 bore or smaller .051 thick $160 shipped
  28. BOP composite cam sensor gear install & removed never used cost $145 shipped sell for $120 shipped
  29. BOB BAILEY 2 step $210 shipped
  30. belt tensioner less then 1000 miles on it $160 shipped
  31. SOLD adjustable boost controller had inside cab $35.00 shippedSOLD
  32. SOLD SFI flexplate neutral balanced $80.00 shipped SOLD
  33. RJC 5" down pipe just bolted on 1 5/8 puck $500 shipped
  34. rebuilt power steering pump with new rubber lines the only line that was not replaced is the short metal one that goes behind pump $160 shipped
  35. weber timing chain .005 under great shape $50.00 shipped
  36. valley pan used goes under intake $40.00 shipped
  37. gn1 head studs used $70.00 shipped
  38. coil pack modules bracket & firecore wires module & coil 1000 miles $165 shipped
  39. gm 3.5 mass air flow meter perfect working order $75.00 shipped
TTT
TTT 885 lifter sold dls cam sold 80lbs injectors w/ chip p/s bracket sold, coil pack module wires sold
