Hey guys. I just got my engine in and went to start it. Did the disarm sequence and it starts and stalls like it's armed. I went to the manuel and reread it. I did it the correct way.
I disconnected the battery by the positive lead instead of the negative when the motor was out. I also hooked it up a few times with no motor to roll up/down the window. Could I have zapped the chip? Tps is .44 idle and 4.55 WOT. The back lites come on and I can see the P/N switch change on scanmaster. This was my 1st thought,neutal switch acting up.
I also forgot to add that the trans is not installed yet(tomorrow nite). So the TCC is unplugged. The way I understood it,this should have no effect.
