Jun 15, 2016 #1 T Ttype6 Well-Known Member Joined Aug 17, 2004 Messages 3,902 I'd like to get some feedback from anyone using these springs with fast ramps. Successful or unsuccessful.
Jun 15, 2016 #2 Reggie West Well-Known Member TurboBuick.Com Supporter! Joined May 28, 2001 Messages 2,566 You are good with up to .700 inch lift on those springs. I have done 6 cars mild to wild using those springs and am very happy with the results. Revs like crazy.
Jun 15, 2016 #3 T Ttype6 Well-Known Member Joined Aug 17, 2004 Messages 3,902 Reggie West said: You are good with up to .700 inch lift on those springs. I have done 6 cars mild to wild using those springs and am very happy with the results. Revs like crazy. Click to expand... Did you run XFI lobes? Intake valve weight? Titanium locks and retainers?
Jun 16, 2016 #4 Reggie West Well-Known Member TurboBuick.Com Supporter! Joined May 28, 2001 Messages 2,566 The XFI cam no. Comp 218/212, Comp 224 and 236 solid rollers and a Reed 244 solid roller as well. You don't need titanium retainers but they will work too.
Jun 16, 2016 #5 T Ttype6 Well-Known Member Joined Aug 17, 2004 Messages 3,902 Reggie West said: The XFI cam no. Comp 218/212, Comp 224 and 236 solid rollers and a Reed 244 solid roller as well. You don't need titanium retainers but they will work too. Click to expand... Did you use these springs with bigger/heavier valved aluminum heads?
Jun 16, 2016 #6 Reggie West Well-Known Member TurboBuick.Com Supporter! Joined May 28, 2001 Messages 2,566 Yes. Used them in stock iron heads andTAs aluminum heads fully ported and polished.
