Comp turbo housing
84AireCaliente
Does anyone know if a precision 65mm wheel housing will work on comp 65mm wheel? What are thoughts on the oil less turbo?
Youd have to be more specific. The older 65 turbines that were superceded by the 66 were actually turbonetics F1 65. You would need to measure the inducer/exducer and compare the radius. Its best to try it on the turbine. Ive seen a lot of oddly machined parts and the turbos are becoming more bastard as time goes on. All the companies are having their own stuff made and they all vary a little. I have no feedback on oil less cartridges.
It is a f1 65 I have. I dont want to buy the comp turbo if it will not bolt up and was hoping I'd get lucky here. I'm going to call comp and speak with tech.
bison, I do not have the tool to measure my f165 wheel, do you know the specs I will need when I call comp to see how close it is to their 65 wheel is to the precision 65 wheel.
Tell comp it's a 65f1 and see what they say
