Compatible ecm?
rag231
When I try to start the car and turn the key to the run position the check engine light flickers. If I knock on the ecm like the police knocking on the door about 5 or 6 times it corrects itself and the car starts and behaves normally. :confused: It is the factory 87 ecm that ends in part#148. Are there any compatible ecms that can come out of the junkyard out of any other cars?
This is a re-post from a search on "ECM Donor Cars" :
From the Hollander Interchange Manual, 1993 edition.
Hollander interchange number 1554.
ECM, GM service number 1227148.
86 3.8 FWD Buick (Park Avenue)
86 3.8 Century (small FWD)
86 3.8 Cutlass (Ciera, FWD)
86 3.8 FWD Olds (Delta 88, Ninety Eight, Regency)
86-87 Regal 3.8 turbocharged
89 Firebird 3.8 (turbocharged)
Note: Only use ECM # 1227148 with your TR prom chip and cal-pack.
Your problem may be how your chip is seated or with the chip itself. Pull it out and check the prongs and re-insert it, or try another chip. I also have ECMs for $75 shipped if that helps you.
