Complete stage II/stage II Enging FOR SALE w/Big Stuff 3 w/Stand Alone harness
The best of everything.......
274c.i. Buick On-Center Stage II Block (4 Bolt Main Caps)
4.020 Bore
Weisco Pistons w/ Tool Steel Rings
3.625 BMS Crank
Carrallo 6.5 Rods
Comp Solid Roller Cam
T/A Timing Chain
Solid Roller Lifters
Billit Cam Gear
Composit Cam Sensor Drive Gear
BHJ Harmonic Balancer
JW Flexplate
Duttweiler Oil Pump
Fittings & Hoses for Oil System
Deepend Oil Pan
H.V. Front Timing Cover
Water Pump
Buick Stage II Heads w/Crane Rockers / Flows over 340
ARP Head Studs
Cometic Head Gaskets
Solid Motor Mounts
Under Drive Pulley
Edelbrock Tunnel Ram Intake
Custom Buick C-N-C Intake Cover
Converted Intake to Fuel Injection
Stock Linkage works with Intake
Cometic Intake Gasket
75mm Throttle body
Limit Eng 76 Turbo
PTE Front Mount Intercooler w/powdercoated Pipes
C.P.P. Stage II Headers
Custom Downpipe
Tial 46 mm Wastegate
Copper Header gaskets
160 lbs Inj
Aero-Motive Fuel Pressure Reg.
Billit Fuel Rails
Coil Pack & Module
MSD Plug Wires
Accel Fiberglass Boots
200 Amp Alt
All Sensors come with package
Oil filtration System w/-10 Oil lines
Inline EARLS Oil Filter (before oil pump)
Comes with EVERYTHING under the hood
Engine has 1000 Street miles on it (never had it to the track)
Over $26,000 invested in PowerPlant & Fuel Mangement
$16,500 gets EVERYTHING
Please e-mail me at BAGN231@yahoo.com
Thx,
Chris Conley
4.020 Bore
3.625 BMS Crank
Carrallo 6.5 Rods
T/A Timing Chain
Billit Cam Gear
JW Flexplate
Duttweiler Oil Pump
Deepend Oil Pan
Water Pump
ARP Head Studs
Solid Motor Mounts
Under Drive Pulley
75mm Throttle body
Limit Eng 76 Turbo
Custom Downpipe
160 lbs Inj
Billit Fuel Rails
Coil Pack & Module
MSD Plug Wires
200 Amp Alt
Thx,
Chris Conley
