FWIW, compressor map for that turbo doesn't exist if it's from PTE or Limit Engineering. It was never done.
However, you can use the Turbonetics map of the T-62 compressor wheel to get you an idea of it's flow characteristics. One thing to remember is, the map dramatically changes when you change the compressor cover, and IIRC, the T-62 map was done with their 60-1 style compressor cover. (4" inlet, 2.5" discharge) Most TE-62 turbos that I remember, came with the TO4E style compressor cover. (3" inlet, 2" discharge)
The TE-62 starts making steam at around 18psi, and has a sweet spot of 22-28psi. It was rated to support 635-640 flywheel hp when pushed. Some have actually made more, but were pushing the limits of the rotating assembly. That is, if it's coupled with a P-trim turbine wheel. It was an older combination that some people liked, and some people hated. If it's a journal bearing and the motor is a 231-235 CI, you will need a 9" or 9.5" converter that will flash stall to around 3400-3500 to really make it scream from a dead stop punch. A 3000-3200 will spool it up, but not fast enough for my tastes. I like the car to rip from a dead stop punch and that typically takes a slightly higher stall converter.
HTH
Patrick
