Turbo_Shae
- Oct 7, 2003
Please advice on the following technical matter:
I have an 87 GN that is emitting white smoke from the exhaust. At first I thought I had an engine problem because the smoke had a burnt oil smell to it. But, I inspected the Inter-cooler as recommended previously and found that there was an oil build ing up in the area...but once that problem was solved I started smelling the fuel. The fuel pressure at idle is reading 37 lbs. At open throttle the reading is 60 lbs. The chip used to signal the fueling system can be described as black in color and has a red dot on its center. I believe 40# fuel injectors were installed in the vehicle. The following numbers are displayed on the fuel injectors 5208008-0363. I believe the manufacturer of the injectors were Kenny Ball. The GN has an after market "high performance" fuel pump of some type located on the frame forward of the right rear. The pump makes an usually loud buzzing sound when car is driven. I have replaced the O2 sensor with an AC Delco. I was told that I may need a new computer chip. Can anyone recommend the correct chip or recommend an expert that help me find the correct chip? Any help on this matter would be would be greatly appreciated.
