OK.. (cliff notes version)
2.8 Pent 4
2 Gig Memory
ATI X800 Video Card
400 W Power Supply
Computer was turned on one day and I get this "overclock" error message. I pull the side off the computer.
Water cooled system. Water leaked.
Found minor green corrosion on the AGP on motherboard and Video Card (VC)
Framerates at idle are 240 Avg. (use ATI overclock tool).Card is NOT overclocked.
Temp goes from 40°C to 119°C (at idle)
Cleaned out corrosion on the motherboard and video card with Rubbing Alcohol & toothbrush.
Reinstall card... same thing.. slow framerates and too high of a temp. Fan is @ 100% (visually verified too).
I pulled VC fan assembly off and applied more thermal grease thinking this may help transfer heat. same problem.
Thinking my VC is shot, I get a ATI 9800 PRO 128Mb..
Frame rates are 170@idle. Temps are 40°C @ idle and does not go up much more.
When gaming (Battlefield 2) the framerates are still too slow (even w/video settings @ lowest).
SO.... is my motherboard AGP bad or ???? Why are my framerates so slow?
2.8 Pent 4
2 Gig Memory
ATI X800 Video Card
400 W Power Supply
