I don't think there are any added amps either but I do recall when I took mine apart to upgrade the whole system that the dash speakers and the door speakers were wired together in parallel through a connector behind the dash.
So make sure you consider that when upgrading either the speakers or head unit. If you are doing both, then likely not a worry if you are wiring them all separately.
So what are your plans???
