wc351
- Dec 30, 2007
Ok, let me start off on the fact that none of the chips mentioned in my last post are being used. Also thanks to all those that responed. I was working on my 87 changing the fuel filter, wires, plugs, and coil pack, as well as putting in a new fuel pump, car had been sitting and through trial and error replaced these things. I also added over 6 gallons of fresh 93 octane gas. When I tried to start it, it would rev to 2k rpm and shut off, like I turned the switch off. If I fluttered the gas pedal I could keep it running. Then I got the bright idea to remove the chip while running, it instantly cleared up?! I drove it around my neighborhood to see what happened, ran ok but very lean! When I reinstalled the chip while running it was like a new car all over again. The chip that worked back in the car was a Kenne Bell #9006, I also think that this is a newer aftermarket computer. The man I got the car from had 3 computers with 3 different cips in them as well as the 3 loose chips mentioned earlier. Why and how did it run without the chip?????? Any tips before I get a new chip, to make sure eveything else is right. The service book from GM is very hard to understand quickly. Please help. Thanks..
Will
Will
