Can any one help oout. which lock up converter can i use.
stock turbo maybe upgrading later to 44 49 which stall can i use or any recommendations or contact?
My 2800 worked well with a TA-49, if you plan on going up with the turbo- go alittle larger like the 3000-3200. You may want to consider the GT-3255 which is suppose to spool up even better than the 49/44 turbos.
