Converting to 4 bolt.....Am I overlooking anything??
BetMinesFaster
Turbo LSX Trader
Hey guys, Im ordering a 4 bolt housing for my turbo tommorow, I have a PT71GTQ, With the added cubic inches with my mods and the heavy ported GN1's and GN1 intake im thinking that the 3 bolt will be spent, im curious if there is anything im overlooking???
-.81 AR Tang. 4 bolt housing
-new flange to weld to header
-external gate and plumbing
-v-band downpipe with clamp
Modify TA's for external gate and piping into downpipe...
Thanks in advance for the info, Ryan
John, Crazy fast street car, building for a high nine second combo with A gental tune..
Heres what it will have:
109 stroker - 250ci
RJC girdle
program main caps
Raceported GN1's
GN1 intake
218* ish roller cam with T&D 1.65 rollers
large fmic with 3" piping
PT71gtq 4bolt
TA's converted to 4bolt external gate
Maftpro with 83's and 4" intake, mafless
340 walbro doublepumper
billit 200 4r with a 3800 stall
Alkycontrol
And some other misc goodies......
Whatcha think??
Be sure to add in a bunch of fuel before running at high boost/rpm. Just watch the correction factor up top.
I will also be running a wideband and datalogger, hopefully it tunes easy without all the headaches and grumbles!
109 stroker - 250ci
RJC girdle
program main caps
Raceported GN1's
GN1 intake
PT71gtq 4bolt
Alkycontrol
Whatcha think??
Looks good, I would consider a single pump that could get the job done.
They are safer in the long run.
Call Dusty on the converter if you have not already!
