Remaining parts
Short Block: 109 block minimum bore, with 4 billet caps and RJC girdle. Stock polished crank not turned, and stock rods with ARP bolts. JE pistons and pins. Includes assymbled short bolck, oil pan, balanacer, flex plate.
Approx 3k miles and 30 passes since refreshened, with best pass 6.455 @105 in the 1/8.
$3000
Heads: Champion Aluminum with econo port by Champion and extra bolt holes with ARP rocker studs, polylocks. 1250 Shipped (pending sale)
Head Studs: ARP 16 pt. 75 (pending sale)
Intake: Upper Kennybell Polished. 150 Shipped
Throttle Body vaccum block with metal vaccum lines factory 25
Intake: Stock upper, does not have throttle linkage, just butterfly and cross shaft. 25
Throttle Body Stock, 25 Shipped.
Main accesory bracket for altenator , p/s pump, and A/C compressor 70 (pending sale)
Ignition Coil mounting plate 15 shipped
Turbo Braket to bolt turbo to head 40 Shipped
Power steering pump, lines and gear box assymbled. 200 Shipped
Brass oil adaptor that the turbo oil line hooks to by the oil pump. 20 Shipped
Header: Factory passenger side has crack, but I can tig weld it or you can. 35
Intercooler: factory 50
Crank pulley: 35
Water Pump pulley 25
Altenator pulley 15
Throttle bracket 20
Throttle cable 30
Hartline cast aluminum valve covers, with Moroso breathers and splash resistant vent tubes pressed in. 90 Shipped
Pinion Snubber and block 10
Starter shield. This keeps the heat from damaging the starter. 5
Serpintine belt tensioner 75 Shipped
High Volume oil pump 45
Scorpion Roller rockers: 1.65 125 Shipped
A/C delete pulley 45 Shipped
Radiator 120
Factory oil cooler lines 50 Shipped
Fue Rail 35 Shipped
Bosh adjustable fuel pressure regulator. 40 Shipped
K & N filter brand New never Installed. Big 14" with 4" inlet 45 (Pending sale)
T-66 Turbonetics Turbo with 3" V-Band and .81 A/R ration exhaust housing Polished Compressor cover. 500 (pending sale)
ATR Front mount intercooler with blow off valve. Turbo outlet pipe has been clocked to accomidate my set up. Also air box welded on front to increase efficency. 450
