Hi,
Just got my new car here in Scotland (87 T).
Have some overheating issues (annoying since the car came from Florida). I have flushed the radiator vigorously. Not much crap came out but 3/4 filling it shows water flowing through the upper core. I suspect the water pump may be a bit weak. Are there any tricks or things to watch on swapping the pump ?
I have a TT chip and it turns the fan on at 165, but, at idle, the fan was struggling to keep the temp at 170-175, and after we went for a drive, it hit 190, which is way too much. My old GN used to cut the fan on at 180 and off at 160 and could pull the temp down quite quickly. I assume that the TT chip does it differently by trying to hold the temp near 165? Assuming a 160 degree thermostat, the car will drive around fanless at 160, and cut the fan on at 165. Is this a correct assumption.
Now, regarding the fan wiring, there are three wires going from the connector to the fan. One is the earth and the other should go to either side of the resistor. On the car, both go to the fan motor side of the resistor. My assumption is that this means the fan runs on high, no matter which relay is triggered. I am not sure if this is because the resistor has failed (I measured it at about 1 ohm - is this correct?) or the car really needed the fan on high all the time.
I know that one relay has a black/pink wire (the low speed) and one a black/red (high speed). I would think that the black/pink goes through the resistor and the other to the motor side of the reisistor, but the wring layout makes that seem impossible due to the nature of the wires and connector rings.
Also, for some reason, the two green wires coming from the pressure switch on the a/c were twisted together (shorted out)
No idea why that was done but I have separated them now.
I have attached some photos.
Any help appreciated. The car really does fly though ... shockingly quick. Smoke city. :biggrin:
All the best
Sandy
All the best
Sandy
