Cooling fan resistor bypass
Hyboost
Hyboost
For an 86 GN. I broke my resistor when installing a aux transmission cooler. I have a post in the "Parts Wanted" section, asking for one.
I have a one fan system. 4 core, Bee Cool aftermarket radiator installed. Never runs higher than 185.
But, if theres an easy way to bypass it altogether, that would be great. I assume I would want to have it work on high speed right?
If it's a pita I'll just try to find a used one or see if they are still available from GM or aftermarket. So if anyone reading this has a used one to sell, contact me.
Thanks. Ken.
Take the wire from one end and put it on the other end, that will bypass it.
That easy huh? Then it will just run on high whenever it turns on?
I really need a shop manual. I just posted in the "Parts needed" section, "W.T.B. OEM Shop Manual" Thanks.
