Correct Belt Size w/ Ac Delete??
bigal
anyone have the correct belt part number for all stock setup, except for ac delete, the stock belt is squealing sometimes under full throttle? thanks
I've had luck with a stock replacement. Check your tensioner, it may be going bad.
I just walked into a parts store and asked for a belt 1" shorter than stock.
I just helped a friend install one of these on his Turbo-T. The one thing that we found is that the pulley was out of alignment. Adding about 2 washers to each bolt to bring the pulley forward slightly helped align it properly.
The belt now even rides on the original wear mark.
We used the factory length belt and it worked exactly as before. Here is the AC delete puller we used:
Dorman 34224 - Dorman Air Conditioner Eliminator Brackets - summitracing.com
Can I just used the 1" shorter belt to bypass the A/C compressor......I wanna get an A/C delete pulley but just need a fix for a couple weeks
