i'm to the point where i need to either sell my car and start over fresh (most likely) or build up a new engine. If i do a new engine i want to do it right, i dont' have any intentions on running 10's but i would like to have a strong engine, rather than a big turbo to make a little weak engine run good. so i was thinking about building up a stage 2 block with some good heads, get around 200-250hp on the engine alone, then get by with only 10# of boost. should run god and last a long time.
I know it won't be a cheap thing to do especially with a good set of heads. but i think it would work out better than building up a stock block. so without all the high end parts i'm sure most f you guys are using how much could i build a mild stage motor for, ball park numbers.
