cost to get turbo-t rims re-done
BMS1
any know how much it would cost to get turbo-t rims re-done, they are in good shape but the anodized look is gone and they have break dust stains. Also, how much does a new headliner run for a hard top car?
Thank you
Brian
A little ingenuity will get you what you want fairly cheap. Glassbeading the rims will bring them back to life. Assuming there are no gouges to sand out, the machined surfaces should be sanded down with 600 grit wet sandpaper to start. Then move up to 800, then 1000. By now they should look almost new. You might have $50 in the glass beading and $10 in sandpaper cost.
There are lots of ways to replace a headliner on the board by doing a search for "headliner". DIY = $30 in materials.
Professionally done you can be looking at $129 a piece. May be able to get them done cheaper by Bweavy.
