I've been considering alcohol injection for my 87 GN but after reading i'm still left with questions:
1.does the alky show up on a scan tool (i have turbolink) in any form?
2. Can I use the 3 bar map that I'm already using for the turbolink boost harness for both (with the pac)?
3.how crazy can you get with this before it washes the cylinder walls and causes excessive wear?
4.How much extra tuning is involved with alky in general?
And how much more with the pac?
5. Does this affect turbo spoolup? my car is slow as hell with the stock converter.
I'm sure i can think of more. this sounds like what I want to do and if i do it I'll be buying it as a kit (probably from razor) to make sure I get everything I need and matched. And in case you were wondering my car is an 87 GN with the following mods: forged pistons, 200/200 cam, te-44, 009's, ATR 3-inch dp with wastegate, walbro 307 (i think) hotwired, adj fpr, t-link, and soon to have a power plate also. my ultimate goal here is to run 21-22 psi on 91 octane and NO KNOCK. what do you guys think?
bob
bob
