I finally finished all the stuff I wanted to do for my winter buildup! Took the car out for a ride yesterday, did some part-throttle blasts and then got on it hard and was greeted with about 2 LOUD (as in gunshot-loud) backfires. Turns out the boost was at 20 psi Got a THDP and RJC PP, I think that's why it was so high (never checked the WG rod length after installing tht THDP ) Got about 4* of KR. So I turned it down to 17psi. Started playing with the FP, as I think it's way too rich for my combo right now (set at 44psi, line off), as it's still stumbling and sometimes popping at WOT. Boost seems to hold steady. It seems worst if I just floor the throttle. If I 'roll' into it it's not anywhere near as bad, almost nonexistent.
I noticed that there is a rattling noise now coming from the engine. Take a couple 3/8" nuts and tumble them around in an empty coffee can, that's the sound. The waterpump is not leaking and the pulley does not wobble. I did the 'screwdriver stethoscope' test and it sounds almost like the noise is coming from the turbo. I never removed any part of it except to put the THDP on, removed the stock elbow. I took the MAF pipe off, the compressor wheel spins, but doesn't 'freewheel', it stops as soon as I take my finger off of it. Is that normal, or should it keep spinning for a few revolutions?
Could I have wrecked the timing chain or cam sensor with the hellacious backfires?
Lastly, the trans shifts seem to have gotten a little soft. The fluid level is OK (changed it late last season). I did remove the throttle cable bracket from the doghouse when I did the 009's and JJ TB and Plenum, but did not remove the TV cable from the bracket. Should I try re-adjusting it anyway?
Thanks for the help.
