Hello,,, this is my first post,, I'v been a lurker for a while reading all the great info,, now is the time to ask questions,,LOL. First and very important,, I do not have the privilege of owning a GN/MC/SS,,(I admire your cars!!) I have a 73 vette with a transplanted 200r4.
Over the past winter I rebuilt a 200r4, installed a Sonnax shift kit (possibly a mistake), installed a 2200-2600 converter (suggested to me from a reputable builder to suit my needs and engine specs).
Its installed and works well, TV cable is adjusted as per instructions with all the correct brackets on carb.
Problem; 1-2 shift is to fast,, almost instant. I have a stock governor from a caddy,,I beleive this is a problem,, what is the solution ?? springs ? weights? what can I do ?
Question; The converter is doing a fine job,, It takes off like a rocket,, but for driving around its a little loose for my liking,, I was thinking of the following solution,, please advise,,; What if I bypass the pressure switch so that it can be locked in all gears,, I would still have a master on/off switch and would add another switch to the brake peddle. Your thoughts ??
Last question,,, people on the corvette forum.com tell me my shift kit (Sonnax) is not good,, they are very partial to transgo/B&m,, since I beleive you guy's are the pro's on this subject,, I would like to here your comments, Personally,, I feel its working fine and doing its job.
