1. With the new windows version, I can't seem to get the Control-O to overlay a run over the VE tables, etc. Is that gone?
2. How come FAST is set up so you can't save a file without the "box" hooked up. It sure would make it easier to work on a setup at your home PC instead of your laptop hooked to the car.
3. (ok, more than the subject line said) Can i run a Windows version on a box that came with DOS? Example, I have a customer that was setup last year with DOS, can I use the windows update when I tune his car, or do I need to use his DOS?
TIA
TIA
