Couple Resto Questions..
aperrego
Drunk? I'll Check. :)
Does anyone know.....
What the part # for the Console Applique is?
There is supposed to be a light that illuminated the P R N D 2 1 on the center console.. What bulb is that and where does the wire go to?
Thanks!
Applique Kit
The applique kit has long been discontinued from GM. Try Kirbans or Postons for a reproduction kit.
The bulb should be a standard 194 bulb. The wire runs under the console toward the front and is tied in under the dash where a non console car would have an ashtray.
Matt
Original Part Number
I bought one way back when...the part number is 25528763
You basically have to pull apart the shifter area... I thought mine was burnt but turned out that the wire broke off... had to pull it and redo the wire....Now it lights up...
