May 9, 2002 #1 A automorph Member Joined May 24, 2001 Messages 138 When installing braided tranny line fittings, teflon tape or pipe dope?? On the 2 tranny lines at the bell housing, which line is out and which is in? Thanks Andy
May 9, 2002 #2 M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Messages 3,658 The upper fitting is out to the cooler. A word of caution: Do not use Teflon tape on the transmission case threads. It acts as a lubricant, promoting overtightening resulting in cracks.
May 10, 2002 #3 A automorph Member Joined May 24, 2001 Messages 138 Thanks, what about on braided hose Earls fittings in between and to cooler, pipe dope or teflon tape? thanks again Andy
May 10, 2002 #4 M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Messages 3,658 I installed the AN fittings in my tranny cooler circuit dry. No leaks.
