OEM Replacement Pump Recommendations
Apologies, wasn’t clear: 2-3 psi low while idling and the vacuum line off the FPG.
The rail pressure falls from about 40 psi to 10 psi in under 30 seconds.
Had a similar issue. Hose on hanger came loose spraying into the vent tube with gas dripping from the charcoal canister.
