CPT61 Turbonetics Ball Bearing Turbo, Becool radiator w/custom fab. for rc fans
V6UnderPressure
The Artist FKA Scott4DMny
I have for sale a CPT61 ball bearing turbo. If I do not sell it, I am going to use it. Money is getting tight. This turbocharger has a 61mm compressor wheel and 65mm turbine wheel. The housing is the 60 series housing and the turbine housing is a .63a/r. The Compressor is an S cover (4" inlet 2.5" outlet). It has only 1000 miles on it. You can see there is practically no rust on the exhaust housing. The wastegate hole has been ported already as well.
Turbo does NOT include the oil drain fitting and flange that you see bolted to it.
700 shipped for the turbo
800 shipped for the turbo plus a brand new HD actuator.
Secondly I have for sale a Becool regal radiator that has the trans cooling lines only. It also has aluminum threaded spacers welded to the outside with set screws inside for mounting the ramchargers (intrepid) fans. It is beautifully and cleanly done. This radiator alone costs $659. I am including the brand new fan just as you see it in the pics. It has the connector already cut off for splicing. If you need to use the intrepid connector then you will probably have to hit the junkyard. It is becool part number 62018. The link below shows what it is. 500 shipped for the setup.
Be Cool 62018 - Be Cool Custom-Fit Aluminum Radiators - Overview - SummitRacing.com
And the actual pictures.
Would you consider trading the 61 turbo for a rebuilt T-70 with 0 miles on it?
How big is the WG hole opened up?Will a THDP Puck still seal it off?
Very interested.can Paypal later today.
Radiator is pending sale.
I measured the wastegate hole and it is just a millimeter over 1.25 inches.
