Originally posted by JRIGSBY_WE4 Is there such thing as 15psi of crappy boost and 15psi of quality boost? So when my header is fixed, 15psi will produce alot more power than now?
Well, it isn't that you'll make more power, you'll be making 15psi cleanly. If you have any faults in the system, i.e. cracked header, the ecm will have to compensate because of what it is seeing from the sensors. This will cause you to lose performance.
Equate it with a stock radio at a static decibel level. Compare it to a properly amped radio at the same decibel level. You get nice clean sound. Ever hear rap music played loud through a crappy stereo?
