Apology accepted. Since my name was mentioned and you claimed you had a bad injector driver despite my findings, I felt I had to set the record straight. If that was not your intention, I'm sorry for jumping the gun.
I am a little confused as to how a cylinder "that's not getting any fuel" can blow head gaskets.
As I said before, the most likely failure mode of an injector driver would be either shorted (on continuously) or open (off continuously). Either one would still be rarer than hen's teeth in my experience. Even more incredible would be a failure mode that would cause a partially rich or lean condition. Since injectors are either full on or full off in operation, there really can't be an electrically static condition that would change the flow. It's only the duty cycle of the injector (on time vs. off time) that determines flow. It is a timing thing, not really a voltage or current thing. I would never discourage someone to test for a faulty driver but it would require some specialized test equipment to look for any other failure mode of a driver. I think there are more likely other causes for a single cylinder fueling problem that should be looked for.
Regardless, for those that want to test a fuel injector driver, the simplest method is a "noid" light. Anything more elaborate would require an oscilloscope and a 2 ohm, 100W dummy load or test injector. I prefer the dummy load for this kind of testing because it is not inductive and makes for clearer waveforms on the o'scope. At 2 ohms and 13 volts, the current will try and go to 6.5 amps but the driver will foldback the current at 4 amps and drop the current to 1 amp for the remainder of the open time. This activity is hard to see on a noid light because without the injector or load present to get the current to 4 amps, the driver will just saturate. This is usually the best test for the field because it does show the driver is trying to switch. It does not test or stress the driver to make sure it's functioning properly however. That's why the dummy load or test injector. A noid light paralleled across the load doesn't work that well because the voltage drop on the injector for the 1 amp hold is only 2 volts and hard to see on the light. One other simple test would be to use the diode test funtion of a multimeter to check for a short in the driver output circuit of the unpowered ECU.
Lance
