Craig - One more try...
DOHC Vobra
Hey Craig,
Since Mike is out this week, I figured I'd try and repost this question and see if you knew the answer... I'm using the Nitrous function of my FAST as a RPM Window Switch...to turn on at a specific RPM, and hopefully turn off when that RPM is gone below... my question is, do you know if the Nitrous control would provide an accurate RPM window switch? Or is it a pretty latent updating mechanism???
Thanks!
Justin
'97 Cobra Coupe
http://www.guieectuner.com
http://dohcvobra.corral.net
The only reason that there would be a delay in the nitrous output activation is if one is programmed into it. In case you weren't yet aware, if you have the number of stages set to 1, the second stage delay will actually apply to that single stage. Could this be your bug?
Thanks Craig!
Craig,
Hmmm...that could be it!!! I think I do have the number of stages set to 1, and there might be a delay set for the 2nd stage...I'll check it out!
Thanks a million Craig! :)
Justin
