crank sensor setting
next_level
just wondering what the setting procedure for the crank sensor is....search wont work for me
Just loosen the 1 clamp screw, and use some shim material, like the carboard of a pack of cigarettes or something about that thick, and place that shim material on both sides of the interrupter ring, and push the sensor over it so that the sensor has equal clearance on both sides of the ring. Then tighten the screw. I hope you meant crank sensor and not cam sensor.
