XLR8ER
Just a Car Guy
- Mar 30, 2002
I bought a used GN engine. After a complete rebuild I have discovered the interuptor ring is slightly bent... which scraps the crank sensor.
Can this ring be removed (and replaced) from the harmonic balancer ?
If not, is there a way to straighten it out so it will not rub the crank sensor ?
Has anybody else seen this problem ?
Thanks in advance !
Thanks in advance !
