crank windows to power
aaron85
i was looking to see if i can change crank windows to power. also if i can do it what would i need to do it. thanks
If the slow OEm units are a issue, install the Electric Life motors.
You will have to add wiring, switches.
I would dispute that its not worth the labor/cost. I even have the "turbo" kit on mine and still not at modern speed. It boils down to personal preference.
Whats this "turbo" kit? Is it anything like this one? I've got an auto down/up w/relay upgrade installed and the speed is way faster than stock. Never heard of the "turbo" kit but I'm if its different from this one.
You know I'm not really sure. The previous owner/longtime friend had installed it prior to my ownership. I do know the hot wire runs to the back of the alternator along with the fuel pump hotwire.
