May 24, 2003 #1 H hwfstru Member Joined May 29, 2001 Messages 121 What size socket do I need for the crankshaft balancer bolt?
May 25, 2003 #3 bird Member Joined Feb 20, 2003 Messages 432 1 1/8 will work but its slightly loose. The actual size is a metric 28mm.
May 29, 2003 #4 S Scott231 Mean Scott Joined Oct 2, 2001 Messages 2,110 Originally posted by bird 1 1/8 will work but its slightly loose. The actual size is a metric 28mm. Click to expand... With that I concur. I use a 28mm socket - perfect fit.
May 29, 2003 #5 R Red Regal T Senior Member Joined May 24, 2001 Messages 19,243 .....................PICKY, PICKY, PICKY...........
