I few weeks ago I decided to change the exhaust and headers on my car(90 stang, supercharged). I went up in size on the headers and from 3" to 3.5" exhaust. then I changed my head gaskets as a preventive maintinence thing(have done this many times with no problems), I fire the car up and its idling ok, I fire up the laptop so I can set the timing, my Crank Ref angle is set at 10°. usually my timing table says 30° where the bubble is hovering(whole block of cells) and the box in the dashboard reads roughly 24°. well now it reads 30° in the dashboard too.....what happened?. then once the car gets alittle heat in it, the idle starts going bonkers rolling from 500-1500rpms.......then smooths out at 1100, then rolls again........A/F will be normal at 13.50:1. then it all the sudden goes lean at 15.9 and idle rolls.....I fatten it up......it smooths.....then goes crazy again and engine starts like missing......then smooths out........am I having a ground problem? did damian invade my car???????
