Well, as I have this thing apart to get ready for a leak down, I notice that the oil galleys are not aligned well at all. I have stock unmodified heads and are original (along with the block).
In my mind, this seems like it could be a very big issue if I'm having any significant crankcase pressure building up. Since the galleys aren't free to flow (about 60 percent of the head provision is blocked by the block), the oil would puddle in the heads and create problems (like it already has) with breathers and valve cover gaskets.
I imagine the factory didn't see this as a problem and it probably wasn't with stock boost levels....but now that I have more than doubled the engineered boost levels, I'm suffering.
I'm really toying heavily with making up some sort of vacuum kit that will eliminate the pcv to throttle body setup and simply pull a vacuum on the engine at all times. I've been looking at electric versus mechanical and they don't seem to be comparable.
It would be easy to add a mechanical pump since my AC pump is no longer used and it would provide worry free operation. If I'm figuring things right, I could tap the original pcv hole for the vacuum and run it through a vacuum reserve (to compensate for any larger leaks that may be larger during wot 1/4 mile blasts) with a oil collection canister/filter to deal with the oil vapors/acids.
As a result, we could maintain around 15" of vac on the case at all times and never have to worry about the dreaded oil getting into the intake or blowing gaskets or simply blowing oil out the valve covers. Also, creating a gauge to measure/monitor the crankcase pressure would help in preventing any future issues with oil leaks if pressure leaks overcome the system. Since most of us eliminate the factory "vacuum" pump (valve cover to turbo evac line), many of us suffer from the excess pressure and vapors.
Anyone with any insight or experience with this area or the vacuum pump setup would be greatly appreciated! The engineering of the mechanical system might take some work, but an electrical system would be fairly simple....so I think
Let me know what you think
