Started to work on the cruise control tonight. Thank you for the information Blaine87. I am a little stumped going thru the checks. Test one passed. Test two did not. I'm not getting any battery voltage between pins A&J in the test chart. Going to Fix B; it says to pull the wire connector C235 and check terminal A for power. The diagram is a bit hard to read. I'm assuming its the connector coming from the 5 amp cruise fuse. Which is the C235 connector in this picture?
View attachment 385923View attachment 385924View attachment 385925
Also, What is the big black box hanging down in the second picture and is there somewhere it should be clipped to like the cruise control module? And again, in the third picture; in the lower left hand corner. What is this connector for? The plug is black and the socket is white with duck tape over it. I doubt this came this way from the factory?
A note; my cruise control light does not light up on the dash if I turn the stalk switch to "on". I did check and ohm the 5 amp fuse. I do have power where the fuse plugs into the terminal block. Pin J is grounded.
Thanks.
