Cruise Control problems
mr.ricoe
Just wondering if anyone would be able to help me with the (CC) ? When I turn it on, the (CC) light turns on but will not engage. Does anyone have a schematic diagram for the cruise control system for a 87 GN ?
There are 2 switchews on the brake arm. One is for cc the other brake lights.
The one with a vacuum line on it is for cc. That switch can get knocked out of adjustment. Push/adjust the switch toward the pedal so that the button is being fully pressed.
HTH
my rule of thumb is ; if cruise light comes on,all electrical is good.....check the vacuum supply at cc servo and vacuum line to brake pedal..
post up what you found so it will help someone who does a search in the future....
Hey was just looking around and noticed the cruise control problem.Changed the powermaster system and after that the cc quit working.Knew about the brake switch not the cc switch gonna have to checkit out
