Sep 25, 2004 #1 S saltydog New Member Joined Jul 21, 2004 Messages 5 My 1987 GN has the cruise control option and it was working fine. I just had the powermaster replaced and now I have no cruise control. Did replacing the powermaster unit have something to do with why I now have no cruise control?
Sep 25, 2004 #2 1KWIK6 UNDER PRESSURE!!! Joined Mar 18, 2003 Messages 225 Check the cruise cutout switch that is mounted under the dash, against the brake pedal arm. It probably needs to be pushed in some more.
Sep 25, 2004 #3 salvageV6 Daily Driver Joined May 25, 2001 Messages 20,992 Yes you probably mis-aligned or mis-adjusted the brake switch on the pedal, or the shop did. There's a switch for electrical as well as vacuum cutoff that must be pushed up against the brake switch with no pedal apply. When you push the pedal down it shuts off the cruise. Check there first.
