Cruise Control
realspartan
Hi Guys,
My cruise control does not work. Any Ideas? Is there a common problem? Let me kmow...
Regards,
Realspartan
Check the switch that mounts to the brake pedal. It can back out just like the switch for the tail lights. Make sure the plunger is pushed in when your foot is off the pedal.
Also check the vacuum lines under the hood, the vacuum ball (under the car), and of course the cruise/turn signal stalk. Sometimes a quick replacement is all you need to do.
