CRUZ Performance
CRUZ Performance
TurboBuick.Com Supporter!
CRUZ Performance
Makers of Turbo Buick Parts to Building High HP Engines that include in Shop Upgrades and Repairs in Our New Facility
Our Priority is to Build and Manufacture these Parts with the Highest Quality And Correct Components that are made in the USA and Tested in House for best Fit and Function
“QUALITY without COMPROMISE”
CRUZ Performance USA made Products are
Turbo Buick Holley engine Harness built to the Manufactures Specs
Injector Harness with sealed loom and 90* Boots
Dual Fan Relay Kits
Stock Style Fuel Pump Hotwire Kits
External Fuel Pump Hotwire Kits
Billet Cam Sensor with MSD Hall Effect Sensor
12-1 Crank Trigger Kit
CRUZ Performance Oil Filter Relocation Kit
LS IAC Conversion
Original IAC Angle Adapter
Billet Aluminum Smart Coil Mounts with Multiple Locations
Billet Aluminum LS Style Coil Mount in Factory Location
Billet Aluminum TR6 Mount
100% Stainless Steel Headers
100% Stainless Steel 3inch and 3.5inch Down Pipes with test Pipe
5pc Billet Pulley Engine Kit
Multiple Plenum Spacers for Stock and Champion Intakes including the CRUZ Performance Angle Spacer that gets the Intercooler Pipe in the correct Position to not hit the Hood Liner
Many 3D printed Products
That include
12.3 Holley Dash Mount
12.3 Bezel
6.8 Holley Dash Mount
7.0 Holley Dash Mount
Dash Connector for Plug in connections for
Turn signals
High Beams
Fuel level
Fuel Rails for Stock and Champion Intakes
Water Neck
Thermostat Housing
Throttle Body Block off Plates
Vacuum Delete kits with remote Vacuum Block
EGR Block Off Plates
E85 Fuel line Kits with Stainless Fuel Filters
MSD Spark Plug Wire Sets for
Stock Coil Pack
LS Coils
Smart Coils
TR6 Coil
Additional Services Provided by CRUZ Performance
Custom Harness made for
FuelTech
Haltech
Motech
And Other ECU’s
Complete Car Wiring Front to back including Stock or Race Style with on Board Relays and Switch Panel
Custom Hoses made with Crimped on fittings
CRUZ Performance is also Dealer for
Holley
Precision Turbo
ACCUFAB
Wilwood Brakes
AFCO Shocks
HR Parts
CRUZ Performance all this and More to COME
Thank you
813-399-0409
Don@cruzperformance.com
CruzPerformance.com
