Ok I have a stock unopened engine other than valve covers and Better V-Springs.
I currently have the 6152E journal barring turbo and would like some advice on what to go up to
Car has a 3200-3400 PTC Non-lock up Converter built trans with Brake and all the suspension mods 60lbs Inj. 340 pump in tank. Razor Alky kit 65mm TB PTE Plenum and RJC p-plate CAS V-4 stock location intercooler and a 3" DP with Eternal Waist gate. (Soon to also have a Dump and electric opener)
Also I run Torco Pump 110 Leaded Race gas as its only $1.50 more than 93 here
I plan to add Better Heads (Either ported iron or out of the box from one of the vendors on here)
Im torn between the 6262 Journal Barring and the 6265 Journal barring. Or maybe the 6265BB and tighten up the converter some for street driving.
What are every ones thoughts? Im looking to go 10.XX and once I get a better short block in with an RJC Girdle and a Nice roller cam maybe high 9's would be sweet!
I dont want to buy 2 turbos just the one
Thanks for the help and info its much appreciated
