custom air to water stock location intercooler for sale
Tom Tom Turbo
Turbo Goes Woo Woo
I am selling this setup because the auto cross class I am going to run in will not allow non-OEM air to water setups and I really would like to try and auto cross this car.
The intercooler itself is a Bowling Green Customs stretch stock location unit that has been professionally built to run air to water. It will accept the stock up pipe and stock mounting brackets, and has been built to allow clearance for the front sway bar. It comes with -10AN compatible fittings already installed.
The pump is a brand new Shurflo 240 LPH unit made for continuous duty use. The final piece is an aluminum Earl's Performance heat exchanger to dissipate the heat from the water as its pumped through the system. You can use this as is or add a fuel cell or tank with added capacity or the ability to run dry ice at the track.
Price is $400 plus shipping, the only thing you'll need to make this system complete is the fabrication of your own water lines between the exchanger and the pump/IC.
pics will be added later or by email request, thanks for looking!
any questions, go ahead and ask away, this is great deal....
The IC alone was $585
new pump was $140
Earl's heat exchanger is $329
pictures attached
