Howdy,
Well the Rivera is short on hood clearance with the stock intake setup and I'm looking for ways to reduce the height. After going back and reading Bruce's Plenum Volume experiments I'm considering doing something to try to smooth out the air and increase the plenum volume in addition to lowering the height of the upper plenum.
Bare with my MS Paint drawings.
Basically its a 4in tall box with a 3.5in pipe cut open in the back to form a deflector baffle. The front is an LT1 throttlebody to keep the GM compatable sensor stuff and for it's lower profile.
I've also thought of another idea but not drawn it up. Still using an LT1 TB it has 2 funnels running off of the back of the throttle bores that are notched down the outsides. The outside plenum is another 4x7x7 box with rounded outer walls to direct air evenly into the hole of the stock or a Champion lower intake.
Thoughts?
Thoughts?
