As some of you know I run a Stage 2 Motor in a Dragster with a 8.71 Hi-Helix Kebelco Blower with a mechanical alcohol fuel injection.  I have had various growing pains with this combination but it has gone a 4.59 @ 155+ in the 1/8 mile.  One of the problems has been a lack of power especially above 6500 RPM, after much reasearch and advise from other racers I am completely convinced that lack of enough valve spring pressure has been the problem and that will be corrected.  Second problem is connecting rods!  I have managed to bend 4 sets of rods (Corollos, Olivers and Crowers) and I am not sure why?  I think its to much cylinder pressure for the rods to handle, others think its got to be hydraulicing.  If it is hydraulicing I can't come up with how, I take various precautions to prevent it but who knows?
Reason for this post! Oliver is currently building me 4 sets of rods that will withstand 300 HP per cylinder. Last week I spoke with the engineer there about the issue of all the bent rods and he gave me the formula (Basic) square inches of the bore 4.030 = 12.755 x 1300 PSI cylinder pressure = 16,582# and said that Oliver rod will yeild approximately 55,000# and thus it had to be Hydraulicing! After mauling that around for a day or two the 1300 PSI just didn't sound right to me. A buddy of mine dug up an article on SCE Gaskets where dutweiller claims on a SBC making 1800 HP @ 42# Boost the cylinder pressures are 3200#! How would the compression effect this ?? More compression is more pressure?? Because I use alcohol I have used 9.6, 10.5 & 11.6 to 1 compression ratios. The higher the ratios the quicker the rods bent. If you take this square inches of the bore 12.755 x 3500 PSI = 44,642# and along with other variables could explain the problem. My real concern is that they are building my new rods with engineering based on 1300 PSI cylinder pressure and I have way more than that!?!?
Questions:
1. Does anyone know the cylinder pressures of certain combinations?
2. How does the compression ratios effect those pressures?
Thanks, Mike Booher
Questions:
Thanks, Mike Booher
 You have a good gasket setup I'm sure, but when excessive force is applied (upwards) the head lifts up and away, which is what allows it to blow. Even at "only" 1800 psi or so, that is like hanging 6-7 GNs off the center of the chamber; it's not hard to see that the head will deflect at that point...
