- May 27, 2010
Hey I installed my Dakota digital dash got to say it's a nice unit! The only issue is I went to turn the car over and the VOLT light is not coming on. Hence my battery is not being charged while the car is running. I wanted to keep my Brake light, Volt light and turn signal working after this install. I tapped the Volt light wire and brake light and turn signal wire from the harness in the dash that plugs into the factory instrument cluster. Ran it to a 12vt socket and then grounded the other end. Neither lights are working. My turn signal lights are working fine. What did some of you guys do to get yours to work. I don't really want to throw a field fix on the car.
