- May 27, 2010
Just got my car on the road so I still need to calibrate the Speedometer. Per the instructions hold the SW1 switch in turn the car on. It should be on SPEED. Then select MPH/KM, then hold button til CAL comes up. Then you have to drive the car one measured mile. To do this either drive your other car and mark off where the mile is at or use a GPS device. When you start it should read CAL on the display! Drive one mile and press and release the SW1 switch. It should be calibrated at this point. Below CAL on the dash will usually read your Odometer but during this process it will be reading Pulse width. It should increase as you go faster and keep moving as your wheels do. The car can stop during this process and slow down. Just have to know exactly where the one mile mark is!! Hope this helps if someone is having trouble setting their dash up!
