Dash panel dimmer switch, buy one where?
tyrod
My dash dimmer switch is popping fuses if it isnt turned all the way down. I need to buy one used or new. TIA
check ebay. There's a seller named GNVEE6. He has nearly everything imaginable...
I got one at a CARQUEST Auto Parts store... DS458 was the part number.
If you have a console, check that the wire for the gear shift indicator light hasn't broken. This is on the dash light circuit and is a common cause for blowing the dash fuse.
David
Thanks, guys. I certainly didnt think about the gear shift indicator light being on that circuit. I have had issues with it in the past.
