Dash removal
belsie
I have a blue Limited interior in the for sale section and am getting a lot of ?? on dash $$, my ? is "how hard is the dash to remove" & any tricks or advice will be appreciated......................
Drop collum, kick panels, I think four bolts on bottom and a few screw on top under speaker cover. May be a few more hidden. Oh the cluster pad and cluster have to be removed also. Probably an hour or so of work. Them you got a few harnesses attached that need to be unhooked or bulkhead unbolted
Very simple. Remove the bezels, then the radio, instrument panel, instrument panel surround, glove box, speaker cover panel and the dash. When the dash is disconnected pull it out a few inches and disconnect the wire harness from the back. 90% of everything uses 7mm wrench, a few 10mm and the speaker cover needs a torx bit, I forget what size. It took less than 30 minutes to get here. Took about 2hrs to button everything up when I was done with mods.
